I need the following function and I’m trying to use the RunOnServer method.- The user has Author access to the db.
The user has read-access to the document since he’s currently not listed in any AuthorNames field
The user need to change the document using an agent.
If possible; doing the above in a local replica as well.
I’ve tried having an agent (foreground) calling another agent using RunOnServer and also tried using a button with the RunOnServer call.
Whatever I try we’re getting “Notes error: You are not authorized to perform that operation”
Now to the strange part: The called agent works despite the Notes error message!
That is; the document is actually updated.
I’ve searched through various forum and gone through Julies articles and the FAQ many times but I’m obviously missing something.
Could someone please give an advice, suggestion, workaround or any other solution
TIA and regards, James
The called agent is set to run on: Event: Agent list selection with Target=None and a Runtime security level of 1 (we’ve tried level 2 also). The agent is signed by me and I can run any agent on the server.
The db has “Enforced consisten ACL” set (if that matters)
Client versions we’ve tried: 6.0.1 CF1 and 6.5.3
They have Author access in ACL without the ability to create any type of agents (if that matters)
Server is running 6.5.2 and everyone can “Run restricted LotusScript/Java agents”
