Stored Procedure Problem
Dim wrk As New NotesUiWorkspace Set ses= New NotesSession
Dim sess As New LCSession
Dim conn As New LCConnection ("Oracle")
Dim db As NotesDatabase
Dim uidoc As notesuidocument
Set db=ses.currentdatabase
Set uidoc=wrk.currentdocument
Hno= uidoc.fieldgettext("A_Hesap_No")
AKod=uidoc.fieldgettext("A_Adres_Kod")
IlceKod= uidoc.fieldgettext("A_Ilce_Kod")
IlKod=uidoc.fieldgettext("A_Il_Kod")
Adr1=uidoc.fieldgettext("A_Adres1")
Adr2=uidoc.fieldgettext("A_Adres2")
Pk=	uidoc.fieldgettext("A_Posta_Kod")
Uk=uidoc.fieldgettext("A_Ulke_Kod")
conn.Server = "Service Name"
conn.Userid = "Username"
conn.Password = "pass"
Call conn.Connect
If conn.isconnected Then
	Msgbox "a"
stored procedure name…
conn.owner="...."
conn.Procedure = "Proc Name"
output parameters declared in the stored procedure…
conn.Fieldnames = "p_hata_kod, p_hata_aciklama"
input/output data…
Dim input_fieldlist As New LCFieldList
Dim output_parms As New LCFieldlist
Dim p_hesap_no As New LCField (1, LCTYPE_INT)
Dim p_adres_kod As New LCField (1, LCTYPE_Text)
Dim p_adres1 As New LCField (1, LCTYPE_TEXT)
Dim p_adres2 As New LCField (1, LCTYPE_TEXT)
Dim p_ilce_kod As New LCField (1, LCTYPE_INT)
Dim p_il_kod As New LCField (1, LCTYPE_INT)
Dim p_posta_kod As New LCField (1, LCTYPE_INT)
Dim p_adres_ulke_kod As New LCField (1, LCTYPE_INT)
Dim p_hata_kod As New LCField (1, LCTYPE_TEXT)
Dim p_hata_aciklama As New LCField (1, LCTYPE_TEXT)
Dim out As Double
Set p_hesap_no = input_fieldlist.Append ("p_hesap_no", LCTYPE_INT)
p_hesap_no.Value = Hno
Set p_adres_kod = input_fieldlist.Append ("p_adres_kod", LCTYPE_TEXT)
p_adres_kod.Value = AKod
Set p_adres1 = input_fieldlist.Append ("p_adres1", LCTYPE_TEXT)
p_adres1.Value = Adr1
Set p_adres2 = input_fieldlist.Append ("p_adres2", LCTYPE_TEXT)
p_adres2.Value = Adr2
Set p_ilce_kod = input_fieldlist.Append ("p_ilce_kod", LCTYPE_INT)
p_ilce_kod.Value = IlceKod
Set p_il_kod = input_fieldlist.Append ("p_il_kod", LCTYPE_INT)
p_il_kod.Value = IlKod
Set p_posta_kod = input_fieldlist.Append ("p_posta_kod", LCTYPE_INT)
p_posta_kod.Value = Pk
Set p_adres_ulke_kod = input_fieldlist.Append ("p_adres_ulke_kod", LCTYPE_INT)
p_adres_ulke_kod.Value = Uk
out = conn.Call (input_fieldlist, 1 , output_parms)
'fetch parameter(s) into the output_parms fieldlist...
(Problem is here)
out = conn.Fetch (output_parms)
Set p_hata_kod = output_parms.GetField (1)
Set p_hata_aciklama = output_parms.GetField (2)
'use the output parameter value(s) in your script...
If 	p_hata_kod.Value(0)<>"0000" Then
   ' Not Success => rollback yapıyorum
	Call conn.Action(LCACTION_ROLLBACK)
Else
    ' Success => Save ediyorum
	Call conn.Action(LCACTION_COMMIT)
Msgbox "Your new sales order number is " & p_hata_kod.Value(0) +p_hata_aciklama.Value(0)
conn.Disconnect
 It is random problem when code is progress until (Problem is here)line. Developer is locked. Is there any body to see this problem before. Thank you.
Subject: Stored Procedure Problem
It sounds like you’re saying that the code hangs at some point, but the line you flagged is not an executable statement. Does it hang on the Call or the Fetch?
If on the Call, bear in mind you’re calling a procedure. Perhaps the procedure is in an infinite loop.
By the way, the Enterprise Integration forum is the best place to ask LC LSX questions.
