I am switching a databse to a new domain. It’s for viewing only. The documents always open in edit mode. I turned that off, but they still open i edit mode because they stored the form with the documents. How can I remove the stored form? HELP!!
Subject: Stored Form Problem
First, remove all of the stored form fields ($Title, $Body, and any other $ field that doesn’t appear on “normal” documents) – @DeleteField will do that nicely. Then set a value for Form.
Subject: RE: Stored Form Problem
Actually, all you NEED to do is replace $Title with Form.
What this will do is to use the database form when the document is next opened. Of cource, you’ll still have the overhead of those other fields.
This can also be used to “refresh” a stored form, as the next time the document is saved from the UI, the modified form will be resaved as the stored form in the document.
