after that I installed NotesSQL 8, as has happened to other users,it appeared the error 126.I already read all the discussions of all forums and I have done everything that I found written: adding the path of strings and update NotesSQL Authentication linst manager.After all this still appears to me the error 126.What can I do?
thank you very much
Subject: Same problem here
I actually had to resort to finding a spare machine & installing Notes 6.52 + NotesSQL 3.02 onto it. This was the only way to make it work. As I need this just once or twice a year it might be a viable solution for me but certainly not for anyone else. Could someone from IBM actually take a look? None of the obvious solutions (PATH, install type etc…) worked for me…Josef Prusa
