Still need Help with NOTES -> EXCEL
Hi Everybody,
It’s my second try to get some help. The last answers haven’t been very satisfying.
I’m trying to export the Notes Calendar into Excel with help of NotesSQL. After accessing the nsf-file (mail file) I enter the list _Calendar_Entry where I can select all the important things like start time, end time, location etc. but the one important thing which I cannot find are the invitees (required,optional). I figured out that the field name is called “AltRequiredNames” but where does Notes save it in the mail database? I already searched in the whole database.
Is their maybe another way to get the information into Excel? (except the standard export function)
Hopefully somebody can help me?
Thanks in advanced!
Subject: Still need Help with NOTES → EXCEL
All fields are carried in individual documents, so there’s not really a particular place that a given field is stored. If you’re using SQL, what you need is a view which displays that field. I’ll reiterate, though, that the best, or at least the most flexible, way to do this is with LotusScript and OLE.
Would it be safe to assume that you’re coming at this from, perhaps, a background in relational databases but don’t have a huge amount of experience in Notes? I’m not sure how to pitch a response.
Subject: RE: Still need Help with NOTES → EXCEL
Thanks for your help.Your right I don’t have a lot experience in Notes Script. In addition, it was very disappointing after I had all the data I needed except that one little very important field.
I like to try it with LotusSkript.
