I configured the SSO document for my Domino server. everything is working fine, I can connect from server to an other without re-authenticate.
server1.domain.com
server2.domain.com
The problem is if I try to use the server IP, the login page always come back and I cannot connect.
Any idea why?
Thank you,
Alexandre
Subject: SSO DNS Domain and IP problem
As far as I know, SSO is based on DNS domain.
It means it cannot work with IP address by concept.
Alain
Alexandre,
Alain is right. SSO is only meant to work within the same domain. An IP address does not match the DNS.
If you use SSL it gets even more restrictive.
This is as it should be, otherwise how do we know that you (with an IP address) are a valid user?
Regrads
Rolf Pfotenhauer
Subject: RE: SSO DNS Domain and IP problem
Thank you for your answer!!
