Dear All,
I want to change the Dateformat from dd/MM/yyyy hh:mm to MM/dd/yyyy hh:mm:ss for inserting into sqlserver table.
can please help with code snippets?
My code:
Dim EmailReceivedDateTime As String
Dim EmailReceivedDateFormat As String
EmailReceivedDateTime = Cstr(doc.Created)
EmailReceivedDateFormat =Format$(EmailReceivedDateTime , “mm/dd/yyyy”) 'It is not working
Subject: Your Format usage requires a datevalue not a string.
I think you have several problems with your approach in code:
The format feature you need requires you to supply a date variable not string.
You converted your date variable to string, which seems unnecessary.
Instead try the 2 lines to replace your previous 4:
EmailReceivedDateFormat =Format$(doc.Created , “mm/dd/yyyy”)
-Kyle Huang
