We are experiencing an odd issue when extracting data from some iSeries DB2 files using SQL statements from inside Notes. The following statement returns a result of x values for ABAN8:
SELECT COUNT(ABAN8) from JDRFILES.F0101,JDRFILES.F0301 WHERE ABAT1 = ‘HOE’ AND ABAN8 = A5AN8 AND A5ACL >1
We we execute the following code, and get (x-2) documents created. If the source data changes, x can change, and different values for ABAN8 are left out. But 2 values remain missing from the results. Any ideas would be appreciated.
selectstmt = " SELECT ABAN8, ABALPH, ABMCU, A5CPGP, A5TXA1 from JDRFILES.F0101,JDRFILES.F0301 WHERE ABAT1 = ‘HOE’ AND ABAN8 = A5AN8 AND A5ACL >1"
tcnt = 0
qry.SQL = selectstmt
Set result.Query = qry
result.Execute
If Not (result.IsResultSetAvailable) Then
Exit Sub
result.FirstRow
continue = True
While continue
Set doc = New NotesDocument (db)
doc.Form = "empkey"
acnt = acnt + 1
Call result.GetValue("ABAN8", tmp1)
tmp2 = result.GetValue("ABALPH", tmp2)
tmp3 = result.GetValue("ABMCU", tmp3)
tmp4 = result.GetValue("A5CPGP", tmp4)
tmp5 = result.GetValue("A5TXA1", tmp5)
doc.AlphaName = tmp2
doc.AddNumber = Trim(Str(tmp1))
doc.DC = tmp3
doc.PriceGroup = tmp4
doc.TaxCode = tmp5
Call doc.Save (True, True)
If result.IsEndOfData Then
continue = False
Else
result.NextRow
tcnt = tcnt + 1
Wend
