Hello,
I have an agent that runs every night fetching records from a MySql database. It should contain over 700 records. This returns in Notes only 335 records.
I have loged on to MySQL server and ran the query on the mysql dashboard to see if it was some problem in the database, but no.
Here is the code I’m using:
Set con = New ODBCConnection
dataSource = “Racktables”
Set qry.Connection = con
Set result.Query = qry
If con.ConnectTo(dataSource) Then
qry.SQL = "SELECT * FROM RackObjectHistory where name is not null"
result.Execute
Do
Set doc = db.CreateDocument
doc.Form="Racktable"
hostname = result.GetValue("name")
id = result.GetValue("id")
ctimeString$ = result.GetValue("ctime")
Set ctime = New NotesDateTime(ctimeString$)
Call doc.ReplaceItemValue("commonname", hostname)
Call doc.ReplaceItemValue("id", id)
Call doc.ReplaceItemValue("ctime", ctime)
Call doc.Save(True, False)
result.NextRow
Loop Until result.IsEndOfData
This returns only half of the posts in the sql database
Please if someone has any ideas, don’t hesitate to share.
Johan
