Hello there; I’m new with lotus domino, and i discovered that all spam on accounts come from internal accounts. Then, i test a telnet lotusserver 25 and i check that i can put commands (like email from, rcpt to…) without any authentication. How can i solve this? what is the “correct configuraction” in order to avoid this spam type?.
In adition, i tried to configure the account by pop3 client, but i only can check the mails. When i try to send to external account (gmail, yahoo, etc) i get the error “rejected by policy reasons”? what policies?? where? i don’t found it.
Any suggestion? documents? it would be appreciated.
(IMAP) Mail
(POP) Mail
(SMTP Inbound) Mail
(SMTP Outbound)
TCP/IP port number: 143 110 31436 25
TCP/IP port status: Enabled Enabled Enabled Enabled
Enforce server access settings: No No No N/A
Authentication options:
Name & password: Yes Yes No N/A
Anonymous: N/A N/A Yes N/A
SSL port number: 993 995 465 465
SSL port status: Disabled Enabled Disabled Disabled
Client certificate: No No N/A N/A
Name & password: Yes Yes Yes N/A
Anonymous: N/A N/A No N/A
it’s ok? suggestions?. Why SMTP inbound and outbound are different?.. inbound is 31436…?? i can’t understand inbound and outbound concept… smtp are a protocol… right?
On the first point you need to check/configure the SMTP Inbound Controls in the configuration settings for the server.
It’s under the Router/SMTP - Restrictions and Controls - SMTP Inbound Controls tab in the configuration settings.
On the second point, Domino performs anti-relay by default when you set up a server. If you need to adjust this, the place where you can do this is in the ‘Inbound Relay Enforcement’ in the configuration settings mentioned above.
