Sorting Problem
Hi All,i want to sort field values.
below are field values:
Allocation Method 5 -All Db
Allocation Method 10-All Db
Allocation Method 11 Db
Allocation Method 7 - All
Allocation Method 8 Db Plans
Allocation Method 9 Db
i tried alot but it is showing above values. it is showing 10 and 11 values before 7. i want sort like this 5,7,8,9,10,11.
Please help me
Thanks,
Prasad
Subject: Sorting Problem
Add a hidden field in the first column with the number parsed out of the value. Then sort by the hidden field.
@Middle should work. You will probably have to return a number instead of text.
