Sort problem
We migrate from windows to linux and our views sort stop working correct. Then we set up Country_Language=fi_FI
…and new documents start sort fine but
all old documents are not. They stay end of the view and updates don’t efect them.
Subject: sort problem
What happens when you press Shift+F9?By what criteria are you sorting the documents?
Subject: sort problem-our fault but…
We faind the problen - it was design (some extra hide column’s)…
I start missing more information of setting language and sort.
I have found 4 palce (linux 3) to setup this but the relationship is not clear and some parameters are not documented in domino administrators help:
NT4 registry
[HKEY_USERS\S-1-5-21-828780090-285152214-48716514-500\Control Panel\International]
“Locale”=“0000040B”
“sLanguage”=“FIN”
“sCountry”=“Finland”
“iCountry”=“358”
“sList”=“;”
“iMeasure”=“0”
“sDecimal”=“,”
“sThousand”=" "
“iDigits”=“2”
“iLZero”=“1”
“sCurrency”=“mk”
“iCurrDigits”=“2”
“iCurrency”=“3”
“iNegCurr”=“8”
“sDate”=“.”
“sTime”=“:”
“sShortDate”=“d.M.yyyy”
“sLongDate”=“d. MMMM’ta 'yyyy”
“iDate”=“1”
“iTime”=“1”
“iTLZero”=“0”
“s1159”=“”
“s2359”=“”
[HKEY_USERS\S-1-5-21-828780090-285152214-48716514-500\Control Panel\International\Sorting Order]
notes.ini
ClockType=24_HOUR
TimeSeparator=:
DateSeparator=.
DateOrder=DMY
CONTENTLANGUAGE=fi
COUNTRY_LANGUAGE=fi_FI
dbdesign.ntf /Database properties
Multilinguage
Default language
Default sort
Unicode sort
db.nsf /Database properties
Multilinguage
Default language
Default sort
Unicode sort
thanks
Antti
