@sort and dates
Hi alli have problems with @sort function when I try to sort dates.
If user has format of date dd/mm/yyyy
then sorting looks like
10/10/2008
15//12/2008
20/5/2008
and it is not user friendly.
could you please hel me with the formula? here is my version
hodnoty:=@DbLookup(“”:“NoCache”;“”:“”;“DPT profile by name”;DPT_name;6;[FailSilent]);
aaa:=@Sort(hodnoty;[CustomSort]; @If(@Date($A)<@Date($B);-1; @Date($A)>@Date($B);1;0));
values:=@Unique(@Text(aaa));
datum:=@Prompt([OkCancelList]; “Select a Date”; "Please select a date for the enrollment "; “”; values);
of course in the end I convert dates to date format, everythings works ok, jus sorting is problem…thanks for advices
Subject: @sort and dates
What happens wheny you change the @prompt to include the [NoSort] parameter?
If your view “DPT profile by Name” is sorted by date… Then I think you only need:
datum:=@Prompt([OkCancelList]:[NoSort]; “Select a Date”; "Please select a date for the enrollment "; “”; valu
Subject: RE: @sort and dates
Thank you.Now it works properly.
