I have a problem, a user will mark the following error and closes the lotus notes.
Sorry, an uncorrectable error has occurred lookup
handle: null handle
Press Enter to abort the application. Shows a red window with that
Need help to fix it. Thank you
Subject: Sorry, an uncorrectable error has occurred. I need help
are there any NSD files in the users data directory?
Subject: RE: Sorry, an uncorrectable error has occurred. I need help
If the files are there. But the problem happens very rarely. After a few days of normal use, the message reappears.Not what you might be.
