Hi all,
I’ve been trying to do this for a while now and could use a little help. I
have a field with multiple values,and another one which is a String. What I’m trying to do, is giving values one by one, to first field
through an action. I select these values,from a view through a DBLookup.
I insert values And I want to sort those values in the second field which is string.
I want to order values,according to a priority, that may be:“0”;“1”;or “2”.
The result must be an ordered list,where the first value will have the value
2>1>0(later I’ll change it in a string). I really have problems inserting values that haven’t a hightest or lowest priority,I say, values with priority “2”, because, user can introduce them like he wants,not in a sorted way.
Well, I think, I haven’t given a good explanation, but…
Any idea or hint would be really appreciate.
The code is down.Trying to order values in string without much success.I
don’t find the correct logarithm.
Thanks, Mary
