Some fonts missing in selection box
We have a new notebook (Windows XP) with about 2000 fonts installed.
When using the Notes client (8.5.1 FP3) then the fonts selection box (from the menu) does not show all the fonts - only about half of it. The list ends with Helvetica…
When using the text properties box, then all fonts are available.
Other applications (like Word, Excel) show the fonts complete.
Any ideas are very much appreciated. Thanks in advance.
Subject: It sounds like there’s a limitation on that particular control…
…and there’s nothing you can do to work around it except, as you have already found, using the text properties instead.
Subject: Found a potential issue in the code, opened SPR #YLJA887GP2 for tracking.
Subject: Same in 8.5.2
Just installed 8.5.2 and am getting the same problem. Fonts in drop down box go up to S but properties box shows all.
Did you get any response from #YLJA887GP2 ?
