[SOLVED, thanks !]Problem with DialogBox - Doesn't display anything but views
Hi everyone !
I hope someone can help me…
Here is what I need to do : I need a dialog box to display a view, but i want the user to be able to filter what he wants to see, i.e. the view display names of all the people, and i want the user to be able to decide if he wants to see only the people that are available, or with a specific speciality, or even the people that will be available on a specific day or for a specific week etc. Problem is, i found out that a normal dialogbox can only display a view. I tried displaying a frameset in which I putted an outline, but dialogbox doesn’t accept framesets. It didn’t worked with Action in my view either.
Anyone have a magic idea ? A miracle or something ?
Thanks !
Emilie
Subject: Problem with DialogBox - Doesn’t display anything but views
have you looked at embedded views?
Subject: RE: Problem with DialogBox - Doesn’t display anything but views
Well thanks, i worked fine with embedded view ! :slight_smile:
