<SOLVED> Strange: Query_String and Path_Info returns nothing
My form did work fine with Query_String and Path_Info field yesterday, but now it suddenly failed. Now these fields return me a empty string!
I had edited some other fields and tables on the form, but not touching the Query_String and Path_Info field. Anyone can give some ideas about how to investigate this problem?
Subject: Strange: Query_String and Path_Info returns nothing
Hi Chi,you didnt specified u r URL which u used to open the form.
If u r opening a agent directly and trying to get the query_string values it wont work. query_string will work only with the forms.
so please give u r url which u have used.
Bye
Kannappan KS
Subject: RE: Strange: Query_String and Path_Info returns nothing
Maybe it is problem about the documents. Now it is solved by 1. setting the field as “Computed for Display”, and the formula is showing its own value.
  1. Re-import all documents (the documents is imported from a spreadsheet)
Then the problem disappeared. Thanks anyway.
