Solution: web unlocking
Form’s onUnload event calls the docOnUnLoad function. The agent gets a handle on the doc with the passed unid, compares who has it locked against who is closing the doc and if the names match, then the doc is unlocked, otherwise just exit. After that, the pausecomp function is called, which is the secret, it gives the agent time to run and unlock the doc. Without it, the onunload is not consistently called. Hope this helps, Kb
function docOnUnload() {
if ( document.forms[0].isNewDocTest.value == “no”) {
var pathname=(window.location.pathname);
var noteid = document.forms[0].docUNID.value;
window.open(pathname.substring(0,(pathname.lastIndexOf('.nsf')+4))+"/webDocUnLock?OpenAgent&ID="+noteid,"_self");
pausecomp(1000)
function pausecomp(millis) {
var date = new Date();
var curDate = null;
do { curDate = new Date(); }
while(curDate-date < millis);
********* code in agent everthing goes into the init sub portion of the agent.**********
Dim db As NotesDatabase
Dim tempDoc As NotesDocument
Dim lockedDoc As NotesDocument
Dim charVariant As Variant
Dim currentholder As Variant
Dim testForDealer As Integer
Set tempDoc = session.DocumentContext
queryString$ = tempDoc.QUERY_STRING(0)
'queryString$ = tempDoc.DocUNID(0)
'Messagebox ("queryString is " & queryString$)
docid$ = Mid$(queryString$, 14, Len(queryString$) )
Set lockedDoc = db.GetDocumentbyUNID(docid$)
If lockedDoc Is Nothing Then
	Messagebox("ERROR - could not find existing document " & Cstr(docid$) )
	Print "<SCRIPT LANGUAGE=JavaScript>"
	Print "window.close()"
	Print "</SCRIPT>"
	Exit Sub
'*********************** NOTE these following lines are necessary for us because we use common names everywhere, you may want to remove this translation if you want to compare heirarchical user names.
currentusername$ = session.EffectiveUserName
If Instr(currentusername$, "/O=") > 0 Then currentusername$ = Strleftback(currentusername$, "/O=")
If Instr(currentusername$, "/OU=") > 0 Then currentusername$ = Strleftback(currentusername$, "/OU=")
If Instr(currentusername$, "CN=") > 0 Then currentusername$ = Strright(currentusername$, "CN=")
Messagebox("currentusername is " & currentusername$)
currentholder = lockedDoc.LockHolders
lockedBy$ = Cstr(currentholder(0))
If Instr(lockedBy$, "/O=") > 0 Then lockedBy$ = Strleftback(lockedBy$, "/O=")
If Instr(lockedBy$, "/OU=") > 0 Then lockedBy$ = Strleftback(lockedBy$, "/OU=")
If Instr(lockedBy$, "CN=") > 0 Then lockedBy$ = Strright(lockedBy$, "CN=")
Messagebox("lockedBy is " & lockedBy$)
'Messagebox ("current holder is" + currentholder(0) + " and the effective user name is " + currentusername$ )
If (lockedBy$ = currentusername$ ) Then
	Call lockedDoc.UnLock
	'Messagebox ("UNLOCKING Document")
	Print "</SCRIPT>"
Else
	Print "</SCRIPT>"
********** end of agent data.
Hope this helps.
