SOLUTION: JVM terminated. Exit code=8096
Hope this helps someone experiencing a “JVM terminated. Exit code=8096” Notes (Standard) client crash . . .
Recently had an R8.0.2 Notes Standard client that would load to the login prompt, then post login you would see the Notes start-up banner with the progress bar in the top-left filling up to about 30%, at which point you get a crash with “JVM terminated. Exit code=8096” at the top of debug text. The user thought that their laptop had previously run out of battery and died while Notes was running.
Re-running the 8.0.2 install and selecting “Repair” did not solve the problem, nor did de-installing & re-installing SUN Java (v6 Update 11).
SOLUTION: Delete all files in the Windows temporary folder (e.g. C:\Documents and Settings<user>\Local Settings\Temp). Apologies that I did not determine which …\Temp folder/file you have to remove to solve the 8096 error.
Hth.
Subject: JVM terminated. Exit code=8096
I had the exact same issue on XP and after deleting all files in the temp directory I was back in business - Thanks
Subject: This helped us also
Thanks James for this good advice! At one XP machine this helped us also and Notes is working well again.
Subject: thanks, helped to me also
That’s a simple and excellent solution.I deleted all the files and folders in the temp folder and restarted the machine, which fixed the issue
Subject: Delete XPDPLAT
The folder in Temp that causes JVM Terminated Error=8096 is XPDPLAT. Deleting that folder will fix the error.
Subject: Lotus Notes “jvm terminated exit code 8096”
Had the same problem on two specific worstations running Vista and Notes Release 8.0.2 FP1 HHF27. Removed the files under C:\Users<username>\AppData\Local\Temp. (Remember this is Vista).
Started Notes and Voilà!. Problem solved.
Thank for the solution!
Subject: Solution: Lotus Notes “jvm terminated exit code 8096”
Removed the files under C:\Users<username>\AppData\Local\Temp (for windows 7)Clear Cache memory.
Subject: SOLUTION: JVM terminated. Exit code=8096
The only folder that needs to be deleted from the %TEMP% directory is “xpdplat”
Subject: Thank you – worked great
