Hi all,
We have tested Soft Deletions with varying times on a R653 mailfile. It appears that there is a limit between 450 and 912 hours. (Clients 654, Domino Servers were 654, now 702)
Our desired setting is 921(38days) as this covers the permanent tape backup cycle.
Unfortunately, as we originally went higher than 900, nothing has actually been automatically removed from Soft Deletions for the past 2years+
Has anybody else noticed this limitation, as other posts have referred to 65000hrs as an undocumented limit.
On finding the problem and running a one off agent to remove the unwanted trash items we saved 150GB ! Don’t fancy looking after the Trash folder via agents though.
Cheers
Paul
