SMTPTranslateAddresses does not work anymore after upgrading to 6.5.1
After upgrading the smtp mail servers from 6.0.3 to 6.5.1 and our internet addresses are no longer being converted to notes addresses on inbound messages.
I have SMTPTranslateAddresses=2 in the NOTES.INI section of the server config document (been there all the time).
Is anyone else having this problem or is it working for you?
PS. Can we have 6.5.1 added to the Release field
Subject: SMTPTranslateAddresses does not work anymore after upgrading to 6.5.1
make sure that you also have MailConvertMIMEonTransfer set to 0, if you have it set to 1 it will not translate the addresses for some reason.
