SMTP Listener problem on Linux
Hi all,
we had a Domino server 5.012 working fine on RedHat 9; yesterday we upgraded to 6.5.2 and now smtp doesn’t work. We tried also with 6.5.1 but with the same result.
The server console shows the SMTP listener task starting, but when I run a netstat -l port 25 does not show up.
When shutting down the server, the console seems to hang at the http task, after a cntrl-c it says that SMTP, and IMAP listener tasks have had trouble with the TCP stack.
Here’s the log:
18/06/2004 11.00.19 AM Unexpected TCP/IP error func: 0004h error Notes: 1C5B, NTI: 1000h, Stack: 00000009h
18/06/2004 11.00.19 AM POP3 Server: Listener failure: Unexpected TCP error. See the Notes log file on this system for error code.
18/06/2004 11.00.19 AM Suspending listen task for 20 seconds due to network errors
18/06/2004 11.00.19 AM SMTP Server: Listener failure: Unexpected TCP error. See the Notes log file on this system for error code.
18/06/2004 11.00.39 AM POP3 Server: Listener failure: Internal Error
18/06/2004 11.00.39 AM SMTP Server: Listener failure: Internal Error
Do you know how to solve this?
Thanks in advance
                 Paolo
Subject: SMTP Listener problem on Linux
I had similar problem with my installation. Tryexport LD_ASSUME_KERNEL=2.25
This should most probabily solve your issue.
Thanks to this forum which helped me solve my issue.
Subject: RE: SMTP Listener problem on Linux
I suppose you meant 2.2.5 instead of 2.25…
For RedHat 9.0, “LD_ASSUME_KERNEL=2.4.1 server” worked for me. Heres what I went through:
Tested SMTP on port 2025, which worked.
Tried SUID on smtp
Tried running it through imapd
Combed newsgroups which failed me.
Tried kernel sysctls which would allow unprivileged daemons on ports < 1024, couldnt find one.
Thought of using iptables to dynamically map a daemon hosted on a higher port, to port 25.
Thanks for this forum, and I hope they put that little info in the Installation PDF.
