SMTP conversion problems to other Lotus Internet domain
HI I have this issue where when I send an email to any domain using Lotus Notes, my email address shows up as jacques page/jacquespage instead of jacques@priorit.ca.
This problem does not happen when I send to MS Exchange, yahoo, hotmail etc… It happens only when I send to other people using Lotus Notes…
I checked the Domain doc, I verified the email address both in the user doc and the location doc,
That problem happens from all my clients including the Web client.
I performed nfixup, nupdall and ncompanct
Domino Directory template is 8.0.1
Anyone would have any Idea?
Thanks a million
Jacques
Subject: a wild guess
Sound to me like the problems are on the dominoservers recieving the mail and not on your server. maybe your recipients are using a very old Domino server.
  • Thomas
Subject: Not really
Hi Thomas.
Other internet domain tested are version 7.03 and 8.0.1 . Even the ones at IBM do this…
I am seriously running out of Ideas… Thank god it works on regular Internet domains.
Subject: MIME
Have you tested using different MIME configurations in location doc and Server configuration Outbound Message options MIME settings.
There are 3 places to y knowledge that could cause this if the sending mail is sent from a Domino Server.
  1. Location Document (may not be an issue as you got the same problem using webmail.
  2. Person Document in Domino Directory
  3. Configuration Document in Domino Directory
-T
Subject: MIME
Yes,1. In location document check for the Internet address
  1. In Configuration document check for MIME->Advance->Advancd Outbound Message Options
Set value of “RFC822 Pharse handling” to “Use CN as phrase”
Hope this helps
