I’ve just upgraded to 6.0.3.The patch version (small) doesn’t seem to work - ok I can live with that.
But we have enabled Smart Upgrade, and to my horror it just asked me to upgrade ?!?!?
There seems to be a bit of work there for Lotus !
cheers,
Tom
cheers,
Tom
Subject: Smart Upgrade : not so smart
If your administrators don’t set the Source and Destination versions properly in the SmartUpgrade database documents, SmartUpgrade will prompt you no matter what version you are running. Search this forum and the Admin Help for more information.
