Smart Upgrade not going silent for me
Greetings,
I am testing Smart upgrade, trying to roll it out to a 7.0.1 machine. The Smart Upgrade is suppose to install silently and Sametime is suppose to be included in the install. When I start up the 7.0.1 machine, I get the notification for the upgrade. I proceed to upgrade and then am prompted by the Welcome screen waiting for the Next button to get pressed.
Since I am quite new to using Smart Upgrade, I would just like to make sure I am doing everything correctly.
Steps taken to roll out 8.0.1 via Smart Upgrade.
  • I have been reading that I need to modify the Deploy\Install.xml file to change the Sametime FeatureID required to “true”. I have done this.
  • I then used SURunas.exe to package up the extracted files into one executable file and place the file in my Smart Upgrade Database.
  • I added some Optional arguments according to another thread so the install would be silent and install Sametime to the Smart Upgrade Kit.
The arguments I added are as such:
-d -s -a /s /v"SELECTINSTALLFEATURES=SametimeUI,Editors,Feedreader /qb+!"
Can someone point out where I am going wrong? My goal is to have the install silent and to have Integrated Sametime installed.
My install kit looks like this:
I appreciate and help that can be given.
Thank you
Subject: Smart Upgrade
If you have the optional arguments in your surunas.exe you do not need to add them to the smart upgrade kit. Check the step by step doc in the following technote:
You may need to add the ALLUSERS=1 to your optional arguments line.
Lotus Software Knowledge Base Document
Title: Using the ‘Smart Upgrade Run As’ feature to upgrade Notes clients
Doc #: 1247849
URL: http://www.ibm.com/support/docview.wss?rs=899&uid=swg21247849
Hope this helps.
Subject: Added Arguments to the SuRunas executable, now what’s happening is…
Thanks for the reply Jana. I have added the arguments to the SURunas package and tried it out. On the client computer it says there’s an upgrade available. I proceed to upgrade the client and it goes through the install. The strange part is that when it finishes, Lotus Notes 7.0.1 is installed. I verified that the files that I packaged up are in fact the 8.0.1 files.
I am in the process of creating a new SURunas package with the ALLUSERS=1 included in the argument.
Just so I have the arguments correct, is this how it goes?
-d -s -a /s /v"ALLUSERS=1 SELECTINSTALLFEATURES=SametimeUI,Editors,Feedreader /qb+!"
Thank you again,
Subject: Smart upgrade silent parameters
The silent parameters look good. Instead of extracting the webkit executable and adding the files to the surunas, try attaching the webkit (.exe you downloaded from passport advantage) directly to the surunas.
Hope this helps.
Subject: Smart Upgrade is rolling out but…
Thanks for your help Jana. It seems that this is working as users are getting the notification. When looking at the log files for these users the Final status is saying Cancelled. I have seen this happen too. The upgrade is performed and says it was upgraded successfully. When the user click ok, it says setup has been cancelled. The user can click on the Lotus Notes 8 icon and it works fine.
Can you think of why the user would be getting this?
Thanks for all your help.
Subject: Log File for one user
Here is the log file for one of the upgrades. Thanks
SmartUpgrade_MYSZKA-41051_2008_08_18@08_09_28.log
[04D0:0002-0570] IN=StartTime IV=08/18/2008 08:20:16 AM
[04D0:0002-0570] IN=FinalStatus IV=Interrupted
[04D0:0002-0570] IN=UserName IV=CN=Lynn Myszka/O=mycompany
[04D0:0002-0570] IN=CurrentVersion IV=Release 7.0.1
[04D0:0002-0570] IN=Version IV=Release 7.0.1 January 17, 2006
[04D0:0002-0570] IN=Type IV=Notes Client Only
[04D0:0002-0570] IN=ProgramDirectory IV=C:\notes\
[04D0:0002-0570] IN=DataDirectory IV=C:\Notes\Data
[04D0:0002-0570] IN=VersionOS IV=Microsoft Windows XP Professional Service Pack 2 (Build 2600)
[04D0:0002-0570] IN=UserNameOS IV=myszka
[04D0:0002-0570] IN=DomainNameOS IV=xyz
[04D0:0002-0570] IN=MachineName IV=MYSZKA-41051
[04D0:0002-0570] 08/18/2008 08:20:16 AM TM=SU: OpenSession: ‘CN=myserver/O=mycompany’ SUTriggerSmartUpgrade()
[04D0:0002-0570] 08/18/2008 08:20:17 AM TM=SU: SUTriggerSmartUpgrade: WksMsgPut(WKSMSG_SMARTUPGRADE…)
[0B10:0002-0B14] 08/18/2008 08:20:17 AM TM=CDeskSubprogram::SubMessageProc: calling SUSmartUpgrade();
[0B10:0002-0B14] 08/18/2008 08:20:17 AM TM=SUSmartUpgrade: Enter: pSUCtx->bTrigFromManual = FALSE
[0B10:0002-0B14] 08/18/2008 08:20:17 AM IN=TriggeredFromMenu IV=FALSE
[0B10:0002-0B14] 08/18/2008 08:20:17 AM TM=ClientGetServerInfoFailOver: ClientGetServerInfo: INITIAL CN=mysever/O=mycompany error: No error
[0B10:0002-0B14] 08/18/2008 08:20:17 AM IN=HomeServer IV=CN=myserver/O=mycompany
[0B10:0002-0B14] 08/18/2008 08:20:18 AM IN=Policy IV=/Smartupgrade
[0B10:0002-0B14] 08/18/2008 08:20:18 AM IN=DesktopSettings IV=SmartUpgrade
[0B10:0002-0B14] 08/18/2008 08:20:18 AM IN=DeployVersion IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:18 AM TM=SUGetSmartUpgradeKitsInfo: User Name: CN=Lynn Myszka/O=mycompany
[0B10:0002-0B14] 08/18/2008 08:20:18 AM TM=SUGetSmartUpgradeKitsInfo: Home Server: CN=myserver/O=mycompany
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Smart Upgrade Database: CN=myserver/O=mycompany!!SmartUpg.nsf
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Smart Upgrade ReplicaID: 01/28/2004 11:10 PM
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Current Version: Release 7.0.1
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Policy: /Smartupgrade
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Deploy Version: Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Desktop Setting: SmartUpgrade
[0B10:0002-0B14] 08/18/2008 08:20:19 AM TM=SUGetSmartUpgradeKitsInfo: Grace Period: 08/29 08/29
[0B10:0002-0B14] 08/18/2008 08:20:20 AM TM=SUGetSmartUpgradeKitsInfo: Current time is: 08/18/2008 08:20:20 AM
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=CurrentVersion IV=Release 7.0.1
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=Policy IV=/Smartupgrade
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=DesktopSettings IV=SmartUpgrade
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=DeployVersion IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=FromVersion IV=Release 7.0.1
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=ToVersion IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=FromVersionOrg IV=*
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=ToVersionOrg IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=PlatForm IV=Windows/32
[0B10:0002-0B14] 08/18/2008 08:20:20 AM IN=Localization IV=EN
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=NumberOfLanguages IV=1
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=LanguageCode IV=EN
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=KitType IV=6
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=InstallType IV=6
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=WCT IV=FALSE
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=KitArguments IV=/v"/qn"
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=AllowedUserStatus IV=FALSE
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=ClientUserName IV=CN=Lynn Myszka/O=mycompany
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=MatchFlag IV=2
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=KitLocation IV=0
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=bRestartNotes IV=FALSE
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=Description IV=LN801
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=HomeServer IV=CN=myserver/O=mycompany
[0B10:0002-0B14] 08/18/2008 08:20:21 AM IN=DatabaseName IV=CN=myserver/O=mycompany!!SmartUpg.nsf
[0B10:0002-0B14] 08/18/2008 08:20:22 AM TM=SUSmartUpgrade: SUBegin: error: No error
[0B10:0002-0B14] 08/18/2008 08:20:22 AM IN=SUG_CurrentUpgrades IV=1
[0B10:0002-0B14] 08/18/2008 08:20:22 AM IN=SUG_MaximumUpgrades IV=10
[0B10:0002-0B14] 08/18/2008 08:20:28 AM TM=UpdateDialogCommand: IDCANCEL
[0B10:0002-0B14] 08/18/2008 08:20:28 AM TM=UpdateDialogCommand: IDCANCEL pCtx->wMaxTimeLeftToupdate B > 0
[0B10:0002-0B14] 08/18/2008 08:20:28 AM TM=DialogCommandAction: pCtx->wMaxTimeLeftToUpdate = B wCommandMsgID = 2
[0B10:0002-0B14] 08/18/2008 08:20:28 AM TM=DialogCommandAction: wCommandMsgID = 2 return IDCANCEL
[0B10:0002-0B14] 08/18/2008 08:20:28 AM TM=UpdateDialogCommand: IDCANCEL DialogCommandAction: dlgResult 2
[0B10:0002-0B14] 08/18/2008 08:20:32 AM IN=ErrorMessage IV=If you choose to update later, you can update manually using ‘File->Tools->Notes Smart Upgrade’ or let Notes automatically prompt you to update. Are you sure you want to update later?
[0B10:0002-0B14] 08/18/2008 08:20:32 AM TM=UpdateDialogCommand: IDCANCEL SUDialogButtonLaterAction: TRUE NEMEndDialog(IDCANCEL)
[0B10:0002-0B14] 08/18/2008 08:20:33 AM TM=SUSoftwareUpdateDialog: NEMDialogBoxParam: dlgResult: IDCANCEL error: Operation stopped at your request
[0B10:0002-0B14] 08/18/2008 08:20:33 AM TM=SUDialogInformationPopup: SUSoftwareUpdateDialog: error = 0x19D
[0B10:0002-0B14] 08/18/2008 08:20:33 AM TM=SUDialogInformationPopup: ERR_CANCEL: pCtx->wPromptInHour = 1 pCtx->wRemindMeDays = 1
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SU_NEXT_UPDATE IV=08/19/2008 08:20:33 AM
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUT_NEXT_UPDATE IV=08/19/2008 08:20:33 AM
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_CurrentVersion IV=Lotus Notes
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_FromVerString IV=Release 7.0.1
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_CurrentRelease IV=*
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_CurrentDate IV=08/18/2008 08:20:22 AM
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_UpdateVersion IV=Lotus Notes
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_ToVerString IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_UpdateRelease IV=*
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_UpdateDate IV=08/18/2008 08:20:22 AM
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_DiskSpaceRequired IV=937
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_DiskSpaceAvailable IV=65772
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_TotalKitSize IV=447688704
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_DriveLetters IV=C:
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_MaxTimeLeftToUpdate IV=11
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_HelpText IV=You have 11 days before Notes is automatically updated.
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_Description IV= This will install Lotus Notes 8.0.1 on your computer. If you have any problems, please call the Help Desk at x1160
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_RemindMeDays IV=1
[0B10:0002-0B14] 08/18/2008 08:20:33 AM IN=SUC_PromptInHour IV=1
[0B10:0002-0B14] 08/18/2008 08:20:33 AM TM=SUSmartUpgrade: SUDialogInformationPopup: error: Operation stopped at your request
[0B10:0002-0B14] 08/18/2008 08:20:34 AM TM=SUSmartUpgrade: SUEnd: error: No error
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SU_IN_PROGRESS IV=0
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SU_NEXT_UPDATE IV=08/19/2008 08:20:33 AM
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SU_DELAY_VERSION IV=Release 8.0.1
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SU_DELAY_DAYS IV=1
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SU_FILE_CLEANUP IV=C:\DOCUME~1\myszka\LOCALS~1\Temp\smkits
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=SUT_NEXT_UPDATE IV=08/19/2008 08:20:33 AM
[0B10:0002-0B14] 08/18/2008 08:20:34 AM IN=FinalStatus IV=Cancelled
IN=StopTime IV=08/18/2008 08:20:37 AM
IN=VersionFinal IV=Release 7.0.1 January 17, 2006
