Small problem with scipt...object varibable not set
hi,
OK Below is part of a script I wrote. It keeps coming up with the error object varible not set. I know what that is. But can’t see it were it is??
In the script, we get to that first message box “do we get here1” but not to the 2nd one that says do we get here2".
I know another set of eyes will see the error in a minute…or less…lol
thanks Kevin M.
Sub Initialize
Dim session As New notessession
Dim db As notesdatabase
Dim  doc As notesdocument
Dim view As notesview
Dim dataview As notesview
Dim datadoc As notesdocument
Dim datapath As String
Dim data As notesdatabase
Dim statdoc As notesdocument
Dim emails As Integer
Dim attachments As Integer
Dim rtitem As Variant
Dim eval As Variant
Dim item As notesitem
Dim EncMails As Integer
Dim foldername As String
Dim sKeepPrivate
Dim sPrivateEmails As String
emails = 0
attachments = 0
sPrivateEmails = ""
Set db = session.currentdatabase
Set view = db.getview("STATPRO")
Print ("Checking Status")
Set statdoc = view.getfirstdocument
If Not statdoc Is Nothing Then
	datapath = statdoc.datapath(0)
	Set data  = session.getdatabase("",datapath,False)
	Messagebox("DO WE GET HERE1")
	If data.isopen Then
	Messagebox("DO WE GET HERE2")
		Set dataview = data.getview("($All)")
		Set datadoc  =   dataview.getfirstdocument
		While Not datadoc Is Nothing
			emails = emails+1
			eval = Evaluate("@Attachments", datadoc)
			If  Isnumeric(eval(0)) Then  ' find Attachments
				If Cint (Cstr(eval(0)))  > 0 Then
					attachments = attachments + Cint (Cstr(eval(0)))
			sKeepPrivate = Cstr( datadoc.GetItemValue("$KeepPrivate")(0) )
			If sKeepPrivate = "1" Then
				EncMails = EncMails + 1
				Messagebox("DO WE GET HERE3")
				sPrivateEmails = sPrivateEmails & (datadoc.GetItemValue("Subject")(0))  & Chr(13 )
				Call doc.ReplaceItemValue("$KeepPrivate","0")
			End If							    				Set  datadoc = dataview.getnextdocument(datadoc)
		Wend
	Else
		Messagebox("Database couldnot be opened")
foldername = ""
Forall v In data.Views
	If v.Isfolder Then
		If 	foldername = "" Then
			foldername = v.name
		Else
			foldername = foldername + ",  " + v.name
End Forall
Messagebox "Database has " & Cstr(emails) & " Emails ," & Cstr(Attachments) & " Attachments and  "  & Cstr(EncMails) & " Encrypted emails " & Chr(13 ) & foldername , MB_OK, "Status Report"
If EncMails > 0 Then
	Messagebox "Database has "  & Cstr(EncMails) & " Encrypted emails " & Chr(13 ) & sPrivateEmails  , MB_OK, "Status Report"
Print ("Done")
Subject: small problem with scipt…object varibable not set
The “” in the getdatabase call means “local machine”. Does the user have this database locally? If not, then use db.Server instead of “”.
