Hi
i m using embeded view on form, it is showing some document(Approximately first 21) at the first page, but if i go for the “NEXT page”(ie clicking) it is not showing any document and saying “No document found” though there is plenty of the document "
Note: embeded view “single category” view formula is "@Name([CN];@username);
Can anybody seek inside this?
Regards,
DEvs""
Subject: single category embeded view “NEXT PAGE” Problem
The view cannot be expected to be broken into two halves on its own. I think we have only option of showing the maximum number of documents at a time or some number like yours ie. 21 docs. If you need to make your ‘next’ to work, create two views showing the first 21 in your first view and then second 21 in your second view.Create your embedded view based on “Choose view based on a formula”(option available when you create the embedded view). Try having a logic and see if you get the next set of docs when you click on ‘Next’ button.
I never tried this before but just a clue to proceed. Please post your comments after try.
Also you need to restrict the view to show only required documents based on the first or last names.
