Simple show/ Hide controls....Pls help
Hi All
I need to show and hide 2 panels on a xpage depending on a condition…eg: I need to show panel_1 when loading the xpage and need to hide it on a button click and show panel_2 how can i do this…Pls help
thanks
shana
Subject: Try…
http://www.bleedyellow.com/blogs/XPagesStuff/entry/a_show_and_hide_example_using_sessionscope?lang=en
Subject: It doesn’t work on a tabbed table
Hi paul,My panel is on a tabbed table…and this doesn’t work…
