I want to show the documents always collapsed whem I use the view. “Collapse all when database is first opened” work only when it is first opened, but I need it always the view is opened. I tried to use “@command([viewcollapseall])” in the postopen object, but it is not working. How can I do it?Thanks a lot.
Subject: Simple question - view - please, help me
This works for me…
a:=@Command([ViewCollapseAll]);
@If(@IsError(a);@Return(“”);a)
In the view postopen event…
Subject: RE: Simple question - view - please, help me
Thanks but It isn´t working for me!
Second tab of the view’s properties, set the “On open” property to “Go to top row”.
HTH
Patrick
PS: I forgot. Get rid of the code in the postopen event. It works randomly thus not reliable.
