I thought @Explode(Goals;“~”;1) will return the first part of the list. It even worked in Computed Text. I dont know why it didnt work in the field. Adding the @Subset has solved my problem. Thanks for yr time.
The reason your original formula worked in Computed Text is that Computed Text doesn’t handle lists - it just cuts off elements so you only see the first part of the list.
The third argument to the @Explode function is a boolean to specify whether or not to include empty elements.
By specifying 1 as the third argument, you’re telling Notes: break Goals into a list, then if there any empty elements in the list, leave them in place.
If you had specified 0 as the third argument, Notes would automatically trim out any empty elements.
However, the list produced by your code doesn’t have any empty elements, so it actually makes no difference what you use as the third argument.
If you only want the first element, then you need to use @Subset.
