Signature Problem
I have a user who’s having a problem with changing their signature. Once they change their signature and click OK, they receive the error “Field is too large (32K) or View’s column & selection formulas are too large.”. I wanted to see what would happen if they left the signature box empty. They still receive the error. Anyone have any insight?
Subject: Having same issue…please help
I am having this same issue as well. I have tried deleting Cache.ndk / bookmark.nsf / perweb.nsf and I have also tried a bunch of ways to uncheck the boxes to try and reset it but everytime I click Ok that error pops up. The new setting is ok until I restart the client.
Subject: Calendar Profile Doc - Signature
I have been searching the 6/7 forums for this issue but have not been able to find it. I did find some info about the Calendar Profile doc. If it is the same in 8 then where would I, meaning my administrator, be able to reset the signature so that this error does not occur. TIA
Subject: Almost Fixed (NOT)
So it seems that it does have something to do with the calendar. If you go Calendar&To> Scheduling> Scheduling, from there if you see something that looks out of place like the times for Saturday and Sunday then correct it. The user is now able to save, but is still receiving the error. I guess that’s better than nothing.
Update***
I thought it was fixed, but it reverts back after closing her mail file. Still searching…
Subject: Fixed!!!
The problem had to do with rules the user had. The user didn’t need the rules so they were deleted and now everything works!!!
