Shell script with timeout
Hello everybody, Can anybody tell me if there’s a way to know if a shell command as finished its execution in lotus script? I must stop the execution of my code until it’s over.
Subject: Shell script with timeout
Not mine, but here:
[Declarations]
'----------Declares for Win32 Shell Control--------------
Public Type STARTUPINFO
cb As Long
lpReserved As String
lpDesktop As String
lpTitle As String
dwX As Long
dwY As Long
dwXSize As Long
dwYSize As Long
dwXCountChars As Long
dwYCountChars As Long
dwFillAttribute As Long
dwFlags As Long
wShowWindow As Integer
cbReserved2 As Integer
lpReserved2 As Long
hStdInput As Long
hStdOutput As Long
hStdError As Long
End Type
Public Type PROCESS_INFORMATION
hProcess As Long
hThread As Long
dwProcessID As Long
dwThreadID As Long
End Type
Declare Function WaitForSingleObject Lib “kernel32” (Byval _
hHandle As Long, Byval dwMilliseconds As Long) As Long
Declare Function CreateProcessA Lib “kernel32” (Byval _
lpApplicationName As Long, Byval lpCommandLine As String, Byval _
lpProcessAttributes As Long, Byval lpThreadAttributes As Long, _
Byval bInheritHandles As Long, Byval dwCreationFlags As Long, _
Byval lpEnvironment As Long, Byval lpCurrentDirectory As Long, _
lpStartupInfo As STARTUPINFO, lpProcessInformation As _
PROCESS_INFORMATION) As Long
Declare Function CloseHandle Lib “kernel32” (Byval _
hObject As Long) As Long
Public Const NORMAL_PRIORITY_CLASS = &H20&
Public Const INFINITE = -1&
Public Sub ShellAndWait(Byval RunProg As String)
’ From Kevin Pauli (kcpauli@usa.net)
Dim RetVal As Long
Dim proc As PROCESS_INFORMATION
Dim StartInf As STARTUPINFO
StartInf.wShowWindow = 6
StartInf.cb = Len(StartInf)
'Execute the given path
RetVal = CreateProcessA(0&, RunProg, 0&, 0&, 1&, _
NORMAL_PRIORITY_CLASS, 0&, 0&, StartInf, proc)
'Disable this app until the shelled one is done
RetVal = WaitForSingleObject(proc.hProcess, INFINITE)
RetVal = CloseHandle(proc.hProcess)
You could also try this (it requires windows scripting)
Dim objShell As Variant
Dim objExec As Variant
Set objShell=createobject("wscript.shell")
Set objExec=objShell.Exec("calc.exe")
Do While objExec.Status = 0
	Sleep 2
Loop
Msgbox "Process Completed"
