I keep getting an error message that there is a type mismatch in the code line where it says: “taskId% = Shell(NetPath", 6)”
Can anyone help me on this …I have never used the shell command before and the way that the help database explains it gets me confused.
This agent is run from the action menu in the database.
Thanks,
Dan
Sub Initialize
Dim session As New notessession
Dim db As NotesDatabase
Dim profiledoc As notesdocument 'The Profile document
Dim NetPath As Variant
'Set NetPath with value from the “DriveMappingCode” field from the Database Configuration document
Set profiledoc = db.GetProfileDocument("(Database Configuration)")
'NetPath= "cmd /c net use \\1.1.222.1\Tiildata\ TIIL!fnp1 /user:administrator"
NetPath= profiledoc.GetItemValue("DriveMappingCode")
taskId% = Shell(NetPath", 6) 'The 6 is used to minimize the DOS command window
Subject: Shell command …type mismatch - help!
I’m not sure if this will solve the problem but I think you need to change this linetaskId% = Shell(NetPath", 6)
to
taskId% = Shell(NetPath, 6)
You do not need the double quotes.
HTH
JB
Subject: RE: Shell command …type mismatch - help!
Thanks James,actually I had corrected that (but forgot to update the content of this post) and it still gave me the same error.
By the way, what does the Taskid% do? Is that the way to execute a shell command?
Dan
Try this…
Sub Initialize
Dim strNetPath As String
Dim taskID as long
Set profiledoc = db.GetProfileDocument(“(Database Configuration)”)
'NetPath= “cmd /c net use \1.1.222.1\Tiildata\ TIIL!fnp1 /user:administrator”
NetPath= profiledoc.GetItemValue(“DriveMappingCode”)
strNetPath = Cstr(NetPath(0))
taskId& = Shell(strNetPath, 6) 'The 6 is used to minimize the DOS command window
HTH
JB
JB,
Nice Catch. Completely missed that data type.
Shawn
Thanks Shawn,
I hope it helped Dan.
JB
TaskId% is setting a local variable of type integer to what is returned from the shell command.
From the designer help:
Return value
If LotusScript successfully starts program, Shell returns the number 33.
What is the NetPath variable set to after this line of code executes?
And did the error get generated when you used this line:
Shawn
