Hi All
@SetViewInfo does not find categories if I have a standard ascending sorted column before my categorised column.
In my view the first column is set to sort ascending by year. The second column is set to be categorised. If I delete the first column and just have the categoried column, @SetViewInfo works fine. If I don’t the message “Category Not Found” appears on the status bar
Hope that makes sense
Thanks for any help
Tim
