Setting toolbar visibility has encountered a problem
I am not sure what specifically causes this problem. I see it most often when I switch my locations, which also involve switching my ID.After the screen/desktop refreshes or reloads a dialog box comes up telling me that “Setting toolbar visibility has encountered a problem”. After that I pretty much have to restart the client.
Subject: Similar problem
I have a similar problem. After switching IDs/Changing Location, the toolbar icons stops working. I have to restart for the toolbar to start working.
Subject: same problem
I’ve also the same problem after switch ID or switch location (with different id) the toolbar don’t work any more.It’s very annoying.
Is there a solution?
Shall this bug been solved in the 8.5.2 version?
Thanks for feedback
Isabelle
