Setting "Search for" in a view - Need Help
Does anyone have any ideas on how I can do the following thing.
I have a form that is in a frameset and when you click on an action Hotspot the following happens:
@SetTargetFrame(“Content II”);
@Command([OpenView];“Name”)
what I want to do is to add a field to the form and then have them enter anything they want and when you hit this action hotspot it would then
do:
***Then insert the search value into this View Search for entry in the view and then searchs on this value
Subject: Designer Help
Check Designer Help > Index > Search forms > described > Customizing search forms. This describes how to set up a form from which users can search. Also check the topic, “URL commands for searching for text”; this describes the URL used to initiate searches.
