@settargetframe doesn’t work with @command(editprofile)
Why the following formula triggered from an outline entry in the “left” frame opens the profile document in a new window while the frame “Right” is available. It works for opening forms or views but not with this action.
@SetTargetFrame(“Right”);
@Command([EditProfile];“profile”)
Using notes client
Subject: @settargetframe doesn’t work with @command(editprofile)
Correct. Why would you expect it to?
From designer help:
Usage
Use @SetTargetFrame before opening or refreshing the view, page, or frameset, or before composing or editing a document. The following @commands use the frame specified in the @SetTargetFrame:
@Command([Compose])
@Command([EditDocument])
@Command([OpenFrameset])
@Command([OpenPage])
@Command([OpenView])
@Command([RefreshFrame])
Subject: RE: @settargetframe doesn’t work with @command(editprofile)
thanks Harkpabst, I must have overlooked that part… you know how what happens to you after a day of coding!
