I have a lot of views in a lot databases.
I can found all my database and
I would like to write an agent who Set “Hide design element from Web Browser” to all views of the database. Is it possible??
In the same time, I would uncheck the flag “Allow customizations”
Thanks for you help
Regards,
Traz
hcl-bot
2
Subject: Set Hide design element from Web Browser using lotusscript
We are also facing the same problem so pls let us know how to check that property programmatically.
hcl-bot
3
Subject: Set Hide design element from Web Browser - solved for all at a time
I just found the solution ofcourse not thru Lotus Script.
To change the design properties of all the views just select all of them by Ctrl + A and choose the design properties to hide it from web browsers.
