I have written a dll that access my notes enviroment and creates a new document in a database. The dll is passed the ReplicaID of the database, plus the form to be used. This all works fine.
The problem I have is when I can this dll from within a dll that runs under the IIS with the user ASPNET. I get the error message: “Notes Error: Could not open ID File” when I try to initialize the session.
I believe the issue is something to do with the HKCU settings as ASPNET is not the current user. If I check the lastused date on the notes.ini, it would appear it is not being referenced, but I believe it is in my Path statement. Can I in anyway direct the session.initialize to a given notes.ini ?
As I say the code must be basically OK as I can use the dll from another programme without any issues.
Public Shared session As NotesSession
Public Shared NotesDb As NotesDatabase
Public Shared Failed As Boolean = False
Public Shared ErrorCode As String
Private Shared Function NotesEnvOK(ByVal ReplicaID As String) As Boolean
NotesEnvOK = True
Try
session = New NotesSession()
Call session.Initialize()
Catch ex As Exception
ErrorCode = ex.Message.ToString
Failed = True
NotesEnvOK = False
Exit Function
End Try
'Open Note Database
OpenDatabase(ReplicaID)
If Not NotesDb.IsOpen Then
ErrorCode = Error2
NotesEnvOK = False
Failed = True
Exit Function
End Function
Thanks for your help
Jeremy
