I havig troubles running a servlet in a domino 6.0.1CF2, when I try to invoque the method evaluate from session class or getFirstItem from Document class I get te following error in the server console:trying to invoque the “evaluate” method
HTTP JVM: NotesException: Notes error: You are not authorized to perform that operation
04/09/2004 04:10:56 PM HTTP JVM: at lotus.domino.local.Session.NEvaluate(Native Method)
04/09/2004 04:10:56 PM HTTP JVM: at lotus.domino.local.Session.evaluate(Session.java:555)
04/09/2004 04:10:56 PM HTTP JVM: at getPortada.doGet(getPortada.java:81)
trying to invoque the “getFirstItem” method
04/09/2004 12:56:28 PM HTTP JVM: at lotus.domino.local.Document.NgetFirstItem(Native Method)
04/09/2004 12:56:28 PM HTTP JVM: at lotus.domino.local.Document.getFirstItem(Unknown Source)
04/09/2004 12:56:28 PM HTTP JVM: at getPortada.doGet(getPortada.java:80)
this is the code of the servlet:
$Author$
$Date$
$Log$
import java.util.*;
import java.io.*;
import javax.servlet.*;
import javax.servlet.http.*;
import lotus.domino.*;
import java.io.InputStream;
public class getPortada extends HttpServlet {
public void init(ServletConfig config){
try{
System.out.println("iniciando...");
super.init(config);
}catch(Exception e){
e.printStackTrace();
public void doGet (HttpServletRequest request, HttpServletResponse response) throws IOException{
//---Obtengo el objeto que me permite escribir codigo html
ServletOutputStream out = response.getOutputStream();
try{
//---[Devfino los objetos]---
Vector vctItemValues=null,
vctItemValuesAlias=null;
Enumeration values, valuesAlias;
NotesThread.sinitThread();
Session s=null;
Database db = null;
Document myDocPortada = null,
myDocNoticia = null;
String strImageName="";
//---[Parametros del Servlet]
String strDatabase="";
String strUser="";
String strPassword="";
String strServer = "";
String strAlias="";
//---Obtengo la ubicacion de la base de datos
try{
strDatabase = "infosalud/infosalud.nsf";
strUser = "Administrator";
strPassword = "password";
strServer = "209.167.44.444";
View newsView;
s = NotesFactory.createSession("", strUser, strPassword);
ViewEntryCollection myViewEntries;
ViewEntry myViewEntry;
Vector myItems;
Item myItem;
int intContadorItems=0;
//---[Inicializacion de Variables]---
//---Login del usuario
db = s.getDatabase(strServer, strDatabase);
newsView = db.getView("portadasToXML");
//---[Entry Point]----
newsView.refresh();
//myViewEntries = newsView.getAllEntries();
//myViewEntry = myViewEntries.getEntryByKey(request.getParameter("categoria"),true);
myViewEntry = newsView.getEntryByKey(request.getParameter("categoria"),true);
response.setContentType("text/xml");
out.println("<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>");
out.println("<portada>");
//while(myViewEntry!=null){
myDocPortada = myViewEntry.getDocument();
myDocNoticia = db.getDocumentByUNID(myDocPortada.getItemValueString("strIDNoticiaPrincipal"));
//---[Noticia Principal]---
out.println("<noticia_primer_orden>");
out.println("<universal_id>"+myDocNoticia.getUniversalID()+"</universal_id>");
//vctItemValuesAlias = myDocNoticia.getFirstItem("strCategoriasForDisplay").getValues();
vctItemValuesAlias = s.evaluate("strCategoriasForDisplay",myDocNoticia);
//vctItemValues = myDocNoticia.getFirstItem("strCategorias").getValues();
vctItemValues = s.evaluate("strCategorias",myDocNoticia);
values = myDocNoticia.getFirstItem("strCategorias").getValues().elements();
valuesAlias = myDocNoticia.getFirstItem("strCategoriasForDisplay").getValues().elements();
out.print("<categorias>");
while (values.hasMoreElements()) {
out.print("<categoria>");
out.print("<alias>");
strAlias = (String)values.nextElement();
out.print(((strAlias.replace('[',' ')).replace(']',' ')).trim());
out.println("</alias>");
out.print("<name>");
out.print((String)valuesAlias.nextElement());
out.println("</name>");
out.print("</categoria>");
out.println("</categorias>");
out.println("<titulo>"+myDocNoticia.getItemValueString("strTitulo")+"</titulo>");
out.println("<copete>"+myDocNoticia.getItemValueString("strCopete")+"</copete>");
strImageName = myDocNoticia.getItemValueString("strImageName");
if(strImageName!=null){
out.println("<image_name>"+strImageName+"</image_name>");
out.println("</noticia_primer_orden>");
Integer intgrContador=null;
//---[Noticias Secundarias]---
for(int intContador=1; intContador<=6; intContador++){
intgrContador=new Integer(intContador);
if(myDocPortada.hasItem("strIDNoticiaSecundaria"+intgrContador)){
if (myDocPortada.getItemValueString("strIDNoticiaSecundaria"+intgrContador).compareTo("")!=0){
myDocNoticia = db.getDocumentByUNID(myDocPortada.getItemValueString("strIDNoticiaSecundaria"+intgrContador));
out.println("<noticia_segundo_orden_"+intgrContador+">");
out.println("</noticia_segundo_orden_"+intgrContador+">");
}finally{
out.println("</portada>");
The user wich creates the session has manager acces to de database and has all the roles, the document has reader fields and I can see it perfectly from notes or web after login.
My situation is desperate, please any sugestion will be apreciated.
I’m compiling the servlet with the j2sdk1.4.2_03 from sun under windowsXP.
Thanks in advance
