Servlet Engine for Domino 7
We are looking to migrate some forms from Domino 5 to Domino 7. At the moment they are using IBM Websphere for servlet interactions but we would like to see if R7 has a production ready servlet engine that we could use instead of install websphere. Hopefully saving a license cost too.
My question(s) is
  • does R7 come with a production ready servlet engine?
  • is using websphere the standard way to do this (considering it’s all IBM anyway)
  • is there any info on the web regarding the R7 servlet engine?
Your help is appreciated.
Cheers
Sub
Subject: Servlet Engine for Domino 7
I’ve written many servlets using the Domino servlet engine. It’s definitely not J2EE-level like you would find in WAS, but it works pretty well for run of the mill stuff. I’ve used it with Oracle using JDBC:ODBC bridge and never had any issues with performance or impact on the rest of the server (which serves both standard client apps as well as Domino web apps).
Subject: RE: Servlet Engine for Domino 7
Thanks for the advice all - much appreciated.
  1. Same as Domino 52. Yes. The license is included with the Domino license.
  2. Probably, but as it’s the same as in 5, don’t expect to much.
