Server 6.5.1. - Client 6.5.3 or 6.5.4 - API Problems "Session.GetDatabase(..)" - I need help
Hi all,
We have installed Domino Server 6.5.1 and the client 6.5.4 (before 6.5.3).
The session object can be created and initialized without any problems:
Dim COMSess As Domino.NotesSession
Set COMSess = New Domino.NotesSession
COMSess.Initialize “ba178”
When we get the database object our VB6 program terminates:
Dim COMDB As Domino.NotesDatabase
Set COMDB = COMSess.GetDatabase(“ABAB/Server”, “hi.nsf”, False)
Why? Is it a “must” that the client and server are on the same release status (6.5.1 or 6.5.3)? Could it be the problem in my case?
Any help is very much appreciated.
Rgds,
Kurt
Subject: Server 6.5.1. - Client 6.5.3 or 6.5.4 - API Problems “Session.GetDatabase(…)” - I need help…
It’s not a version issue; your code never talks to the server. Have you tried going from NotesSession through NotesDBDirectory and using OpenDatabase? Some methods work better in COM than others.
