Sequential numbers - help
this is my code i want to replace the messabox and the numbers from messagebox the sequence numbers i want it, in the field for example when i open the form the messagebox appear a number 8 for example i want the number 8 from my field instead of message box
how can i resolve this any one who help me…this is the code:::
seqNo = session.GetEnvironmentValue("SeqNo")
If Isempty(seqNo) Then
	Call session.SetEnvironmentVar("SeqNo", 1)
Else
	seqNo = seqNo + 1
	Call session.SetEnvironmentVar _
	("SeqNo", Cint(seqNo))
Messagebox session.GetEnvironmentValue("SeqNo")
Subject: sequential numbers - help
Which field? There is no mention of a field in your code
hi jayhson,
i am sorry but i didnt quite get your question. can u explain again, i think i may be able to help u.
Rosie
Subject: RE: sequential numbers - help
i want the sequence number from my fields… because in that case of my code there will be have a messagebox i want the number from the messagebox from the fields…
