Send with LNotes 6.5.4 using VB2008express - Notes hangs
I am trying to send a mail from my vb application.After clicking the button, My Notes just hang up and I have to restart the computer. Please help.
Private Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
    'Lotus Domino Test
    Dim Maildb As Object
    Dim MailDoc As Object
    Dim Body As Object
    Dim ns As New Domino.NotesSession
    'This line prompts for password of current ID noted in Notes.INI
    ns.Initialize()
    'Open the mail database in notes
    Maildb = ns.GetDatabase("", "D:\notes6\data\mail\atapa15.nsf")
    If Not Maildb.IsOpen = True Then
        Call Maildb.Open()
    'Create the mail document
    MailDoc = Maildb.CREATEDOCUMENT
    Call MailDoc.ReplaceItemValue("From", "finding_nemo@hi.com")
    'Set the recipient
    Call MailDoc.ReplaceItemValue("SendTo", "dori_dafish@hi.com")
    'Set subject
    Call MailDoc.ReplaceItemValue("Subject", "Test Sending")
    'Create and set the Body content
    Body = MailDoc.CREATERICHTEXTITEM("Body")
    Call Body.APPENDTEXT("Test message")
    'Example to create an attachment (optional)
    'Call Body.ADDNEWLINE(2)
    Call Body.EMBEDOBJECT(1454, "", "C:\app1.zip") '(1454, "", "C:\", "app1")
    'Example to save the message (optional)
    MailDoc.SAVEMESSAGEONSEND = True
    'Send the document
    'Gets the mail to appear in the Sent items folder
    Call MailDoc.ReplaceItemValue("PostedDate", Now())
    Call MailDoc.SEND(False)
    'Clean Up
    Maildb = Nothing
    MailDoc = Nothing
    Body = Nothing
    'Session = Nothing
Subject: Send with LNotes 6.5.4 using VB2008express - Notes hangs
There’s no obvious reason for things to be hanging, but there are some problems with your code. First, there’s no reason to set the PostedDate item, it’s set automagically when the message is sent. And iff you are going to release Notes objects, start at the bottom and work your way up – use Marshal.ReleaseCOMObject() instead of setting the object to Nothing.
