Selective Replication is not possible without deletion stubs
Hi, this is a repost and I have a severity 1 problem with this. I tried everything with no success. Problem was that Notes is not interested in any Selective Replication when document deletion stubs are gone. I tried to set Cut off date or set the formula
SELECT @Created >= @Adjust(@Now;+1;0;0;0;0;0), but always old documents(with no deletion stub in the server db) reappear. Why ??? Does noone else have this problem, that people do not replicate within the deletion stub life time ?
Please Help
Bye Martin
Here my old post
Hello,
we have a DB on a central server. And a lot of replicas outside. All the time deleted documents reappear on our server as following:
  1. We delete the doc on the server
  2. After some time the deletion stub is gone too(this is normal) on the server
  3. We enable “Only replicate incoming documents saved or modified after 01.01.2003”
  4. Even older deleted docs then 01.01.2003 reappear on our server.
I suppose that the replicator tries to check the date of the doc on his own DB and does not find the doc so the old docs reappear.
Is there any way to avoid this ?
Thanx Martin
