hi!I have to display a view on web, the user will select some documents and click on a button which will generate html file based on the selected documents.
i have the following code
Dim s As New NotesSession
Dim db As NotesDatabase
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Set db = s.CurrentDatabase
Set dc = db.UnprocessedDocuments
Set doc = dc.GetFirstDocument
Do While Not(doc Is Nothing)
{some code}
Set doc = dc.GetNextDocument(doc)
Loop
but i dont get the value of doc…
is there any other way to access the selected docs on the web.
