$$SelectDoc - Problem with one document
I have been using $$SelectDoc to process agents from the web with success, however, I noticed that if there is only one item left on the view, the forms.elements.length for $$SelectDoc returns ‘undefined’ in my js.
If there are two documents in the view it returns 2.
Here is sample code that I have been using. Works fine unless there is only one item left in the view to select. Let me know your thoughts. Thanks.
var cb = document.forms[0].$$SelectDoc;
var selectcount = 0;
var docUNID = new Array();
for(i = 0; i < cb.length; i ++){
if (cb[i].checked){
docUNID[selectcount] = cb[i].value;
selectcount++;
if (docUNID[0] == null ){
alert(‘No documents Select’);
else {
if (docUNID != null ){
result = window.confirm(‘OK to continue’);
//alert(result);
if (result == true) {
document.forms[0].submit();
I reviewed the Forum 4 and 5 but I don’t found any solution.
Any idea?
Thanks in advance.
Subject: $$SelectDoc - Problem with one document
Hi, After alot of searching and modifications, this is what I came up with and it works!!
var oIDs = document.getElementsByName( ‘$$SelectDoc’ );
var check = 0;
//check if if any checkboxs are checked, if not exit
for( var j = 0; j < oIDs.length; j++ )
if( oIDs[j].checked )
	check = 1;
if (check == 0)
alert ( ‘You did not select any documents, please correct and try again.’);
return false
else
//will return an array with all check boxes
//process the array to fetch selected UNIDs:
if( oIDs.length )
		docUNID[selectcount] = oIDs[j].value;
		selectcount++;
 result=window.confirm('You are going to process the selected documents, click OK if you wish to proceed.');
 if (result==true)
	document.forms[0].SelectedDocs.value = docUNID
	document.forms[0].RunAgent.value = "1"
else
{ // just one check box
if( oIDs.checked )
 docUNID[selectcount] = oIDs.value;
