I was on a support call with HCL about setting up AUT Catalog thinking that it's the new way to upgrade Notes clients from 10x to 11x and he said they basically accomplish the same thing. So why did HCL create AUT Catalog?
Hi Quin,
I suggest to go through presentation or recording available in below URL -->
https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0078910
AUT has below advantages over Smart upgrade -->
1)AUT manages privileges transparently, for Smart Upgrade,one must run different process for user with limited rights on Operating System.
2) For AUT, one doesn’t need separate process or steps for user with limited rights on OS that means a Notes user without administrative rights or with UAC enabled can still initiate Notes updates through AUT service.
3) AUT Server side management is simpler.
4) As AUT is extended from Open source Update framework, it is more robust, maintainable, reliable and scalable
5) The communication between AUT client and AUT server is encrypted with SSL Handshake in between them so is quite secured.
I hope this will answer your query.
Regards,
Amit Sharma
I've read some discussion about AUT and non-English versions of Notes.
Do you know something more about AUT and - say - German Notes standard client? Does is work? Is it supported? Are there additional steps to be taken in comparison to the English standard client?
Hi Thomas,
I agrre,there has been some enquiries in past with respect to AUT and non-English versions of notes.
I do not have working results of AUT for non-English version of notes.
However, as far as your query is considered, AUT is supported for non-English versions of Notes Client. It is supposed to work there.
Seeing issues on non-English version of notes, an enhancement was submitted with respect to same in past.
https://domino-ideas.hcltechsw.com/ideas/DOMINO-I-1072
However, if one check the comments section in above URL, then will get information about AUT supporting non-English notes client or not.
In case, one find any issue doing upgradation, suggestion is to add below parameter in notes.ini. Restart the notes client afterwards.
DEBUG_AUT_CLIENT=1
DEBUG_AUT_MGMT=1
Collect the logs after performing above steps and then these logs can be submitted for further investigation.
I hope this could be of help with respect to your queries.
Regards,
Amit Sharma
