Secret and Public encryption on same document
I have an application with documents that have one value in the SecretEncryptionKeys field and then names in the PublicEncryptionKeys field (backend only for this field).I have found that if you are only in the PublicEncryptionKeys field and do not have the Secret Key, you can READ the doc and encrypted data, but cannot edit/save/encrypt. You get the ‘You do not have the ‘xxxx’ secret key’ when attempting to save. (the publicencryptionkeys person is in another Authors field on the form as well)
I am hoping someone knows a way to use both keys, and allow the PublicEncryptionKeys people to edit/save/encrypt the data even if they do not have the secretkey.
Anyone?
